AutoCAD Map 3D General Discussion
Member
kurios-cad
Message 1 of 3 (430 Views)
Esri Shape file to topology
430 Views, 2 Replies
11-13-2002 12:58 AM
xxxxI have imported an ArcView shape file into a drawing.
THe dat is a polygon with the object data associated in a centroid(?).
How do I create a polygon topology using this data. I have not had any luck with what I am tried.
Thanks Tim
P.S. Sorry about my previous message, I accidently hit the wrong key.
*Gazit, Arad
Message 2 of 3 (430 Views)
Re: Esri Shape file to topology
11-13-2002 07:15 AM in reply to: kurios-cad
Tim,
What happens is that when you import an ESRI
polygon shape file is that each polygon has its complete, closed polyline (This
is how Arc-View operates).
In Map you need to "Clean Up" your drawing so that
you will have only one object for each boundary. This involves using several of
the clean-up commands and eventually running "Create Topology".
Good luck,
Arad
xxxxI
Thanks Tim
key.
*Wilson, Neil
Message 3 of 3 (430 Views)
Re:
11-18-2002 04:22 AM in reply to: kurios-cad
Make sure you save your object data to centroids
before cleanup. Use the Mapcreatecentroids command.
Tim,
(This is how Arc-View operates).
that you will have only one object for each boundary. This involves using
several of the clean-up commands and eventually running "Create
Topology".
Good luck,
Arad
xxxxI
Thanks Tim
key.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
