Hello Tim,
I only recognize 2 of the files you mention. The CMP could possibly be your
raster image, there are a number of image programs that use that extension.
You can find a converter here: http://www.xnview.com/ (its free). The ADF is
an ArcView/ArcINFO coverage data file. The CLR could possibly be a raster
image, but usually that one is associated with color tables or color
definitions. You will still have a little trouble with the image, even if
you do get it converted to a format that Map will take, unless you have a
good idea where to place it and scale it without a world file.
You may even dig around in ArcView and find a way to export them.
Good luck.
-Andy
"kurios-cad" wrote in message
news:f1154ed.-1@WebX.maYIadrTaRb...
I recieved some ArcView(?) files from a crient. I can load the .shp files
with no problem. However, I also recieved a series of files with extensions
.Aux, .CLR, .CMP & .ADF that I cannot figure how to load into MAP.
I know they have to do with a raster image (I have a copy of ArcView and can
load them in so I know what they are).
Can anyone help me ?
Tim
