AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
ESC Key and other issues
2 REPLIES 2
437 Views, 2 Replies
AutoCAD Map 3D 2011 -
1) Installed the "hotfix" for the ESC key, but it still has issues canceling a command.
2) When selecting multiple objects, holding "shift" to unselect does not work at all. I have to escape or zoom extents to stop the commands.
3) Constant freezing when zooming in or out
I have swapped keyboards, and nothing works. Also happened on another machine prior to installing it on mine.
Totally at a loss of what to try next. All updates have been applied.
2 REPLIES 2
Alfred.NESWADBA
There was an issue with Photoshop (Elements?) I think. Could it be you have it opened parallel to AutoCAD?
Are there specific objects selected when <ESC> don't work? E.g. happens only when FDO-objects are selected?
How is the sysvar PICKADD (>>>details<<<) set?
Have you FDO-objects active? Can you look to the taskmanager for processor power and memory consumption at this stage (AutoCAD is freezing)?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
We do not run Photoshop. Does not matter what objects are selected.
SYSVAR???
FDO??
It is freezing when zooming in or out majority of the time.
”Boost
