Hey Becca,
At the command prompt type "APPLOAD" without the
quotes.
The window that opens is called "Load/Unload
Applications"
-> click on the tab called "Loaded Applications"
and see if CUT_ORG.LSP is listed If it is, click on it and select
"Unload"
-> next click on "CONTENTS" under the Startup
Suite (same window as the step above). See if CUT_ORG.LSP is listed
there. If it is remove it.
-> CLOSE the window, and you should be
done.
The error message "load failed" is likely b/c the
LISP file is
a. not on your computer
b. not in the search path
Do a file search on your computer and see if you
can find the file CUT_ORG.LSP
If you cannot find it then it's missing from
your computer.
If you can find it, then you must add the path to
autocad. To do this:
-> start autocad
-> select pull down menu TOOLS ->
OPTIONS -> FILES -> click on the + next to Support File search path,
and add the directory where the file resides on your HDD.
Martin
