Thank you Marion. There is a problem. When I modified the coordinate system,
I didn't change any values, only re-entered them. However map sees the
system as changed. Thus I have no way to get it back to where it was,
because it already is where it was.
Any other ideas?
"Marion Pietsch" wrote in message
news:1367AEA6CF0DB8CACE891F8476913E84@in.WebX.maYIadrTaRb...
> If the custom coordinate system was modified, then there's no way around
the
> error message.
> To solve, you'd have to best save the current coordinate system under a
new
> name, then modify the old one back to the originally used parameters, and
> finally do a conversion from the old to the new coordinate system by
> querying the affected drawings.
> Marion Pietsch
> Autodesk Product Support, GIS
> "Neil Wilson" wrote in message
> news:B0DC534C040787A24B4F55975ABCA81C@in.WebX.maYIadrTaRb...
> > I modified a custom created coordinate system and now whenever I open a
> > drawing that was created with the old version, I get the error message.
> > Sometimes it repeats 4 or 5 times before finally letting me into the
> > drawing. Is there a way to prevent this from happening, or do I need to
> > recreate the drawings?
