Does anyone recognize the "Error Creating Map Book" message. It gives no error number just asks if you want to retry. This has been a problem in at least the last three releases.
Hi Deeter,
Are you working in the Mapbook tab, or from the very old MAPPLOT? Does it create anything?
Nate,
I use the Map Book tab. It does not create anything when I get the error. I have checked to duplicate grid blocks, duplicate grid names, done drawing cleanup and anything else I can think of. Since I only bring in portions of the overall coverage at a time there are some areas that plot fine then all of a sudden the area I choose won't build.
deeter
also, are you using an "out of the box" map book template or one that you've modified. I've only really had success with the OTB - but I haven't pushed it that far for my own production work beyond the tutorials/skill builders in the map books arena.
I do recall having challenges trying to set up my own template.
I actually modified an out of box template to suit company standard. I do not think the template is the problem as it has worked before. I use a custom grid with object data and it also has worked before. Those are the reasons that this is a problem. It has worked before and I don't know what happened all of a sudden.
@Anonymous wrote:For anyone following this thread. The answer was that there was an error in my object data.
what did you do in your object data?
What kind of errors in your object data do you mean because I am having this problem
sorry I did not found a solution, I even found more errors, I am searching for alternatives to MAPBOOK command
Post a screenshot of your drawing with an explanation of the error and when the error occurs in your workflow. It would be better if you also started a new thread using a title that describes your error or what you believe is the cause of the error. For best (and fastest) results, upload a copy of your dwg for troubleshooting.
