AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
error connecting a mdb file
6 REPLIES 6
MKH-VB
879 Views, 6 Replies
I have an older water line project that was connected to the file water.mdb.  I am trying to connect the dwg to the mdb and am getting an error.  I have enclosed a screen shot of the error.  FYI i am using 2011 Civil 3d, and the dwg was originlly done in Autocad Map. (2005 I think)  Any help would be greatly appreciated. Also, I am just using drag/drop to attach this dbase.
mkh
6 REPLIES 6
Alfred.NESWADBA
in reply to: MKH-VB
are you now on 64bit Windows? If so you will have to install the 64bit ODBC-driver for MDB (check >>>here<<<, but be careful with your existing MS-Office-installation!).
Or convert your MDB to any other 64bit-compatible database like MS-SQL-Server and get then connected to that.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
antoniovinci
in reply to: MKH-VB
Instead of FDO, what about connecting the .MDB file by means of _MAPATTACHDB command..?
Murph_Map
in reply to: antoniovinci
Agree, if the dwg was from 2005 version then that's how it was connected to it then.
Murph
Supporting the troops daily.
MKH-VB
in reply to: Alfred.NESWADBA
What software would I use to convert MDB to SQL? Mike Henson CAD Manager Hawkins-Weir Engineers, Inc.
mkh
Does not work either in 64bit without the 64bit-driver ;(
If you install the SQL-Server (with all tools) then you have also "SQL Server-Import/Export Assisten" installed (or you can it install afterwards), check >>>this link<<<.
But there are also a lot of tools around data-exchange between different db-servers!
- alfred -
Alfred NESWADBA
phil_borycens
in reply to: MKH-VB
Hello. Assuming that you are running Windows 7 64-bit...
Windows 7 64-bit doesn't handle ODBC the way it used to, so you can't drag & drop Access or Excel files into Map Explorer like you used to on 32-bit.
Please see the following links for instruction on how to do this on 64-bit:
http://gisexchange.typepad.com/blog/2010/08/odbc-on-x64-operating-systems.html
http://usa.autodesk.com/getdoc/id=TS18307898
Phil Borycens
”Boost
