AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Error attaching referance drawings
1 REPLY 1
219 Views, 1 Reply
What causes this error? What needs to be done to correct it?
CLASS DESCRIPTION ISN'T IDENTICAL WITH REGISTERED CLASS.
Parameter; ERRCODE; Value 786434
1 REPLY 1
When do you get this message. I have seen one case
where this occurs when there is a difference in the Description field
of object data tables which are in the project drawing  (current DWG) and
an attached source drawing.
To correct it, you need to make sure that the
Description fields are the same in the two drawings.
Hope this helps,
David Walsh
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
What
”Boost
