AutoCAD Map 3D General Discussion
Member
0 Kudos
Post 1 of 3
Editing SDF schema / properties in Map 3D 2012
279 Views, 2 Replies
04-10-2012 08:57 AM
Hi All,
I was wondering if anyone can tell me how to edit the schema/properties of an SDF in Map 3D?  I need to edit existing properties.  I have followed the instructions in 'Help', but even after clicking on 'Edit Schema' in the schema editor, I have no luck.  I have been able to add/delete properties but have not been able to edit other things (such as existing property titles, display order, Type etc).  From what I understand in Help, I should be able to do this?
I have about 30 SDF files that were converted from SHP using FME.  I know I can manipulate them in FME but each file has different properties and it will take me quilte a bit of time as I am not super familiar with it.
Any help is appreciated!
Kristi
1,210 Kudos
Post 2 of 3
Re: Editing SDF schema / properties in Map 3D 2012
04-10-2012 09:01 AM in reply to: ksmith
yes, annoying for me also.
What I do in that cases: I create a new SDF using the structure of the original one. As this SDF is empty you have the chance to modify/add/remove properties. Then I use bulkcopy to get the data transfered from my original SDF to the one with the new structure.
HTH, - alfred -
Alfred NESWADBA
Member
0 Kudos
Post 3 of 3
04-12-2012 10:16 AM in reply to: Alfred.NESWADBA
Thanks Alfred,
I had a feeling Bulk Copy was going to come into it but was hoping it was just something simple I was missing!  I'm thinking the amount of work is going to be comparable to going the FME route.  But I will give your method a try and see which one is 'easier' for me.
Kristi
