AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
DWG's in ArcGIS
6 REPLIES 6
phil_borycens
1423 Views, 6 Replies
DWG's in ArcGIS
Hi everyone!
Curious about this as a customer asked me about it today.
Workflow:
1. In AutoCAD, WBLOCK objects from a working drawing to a new DWG.
2. In ArcGIS desktop (10.1, and possibly earlier versions), convert the DWG to SHP.
Result: If you do this with a DWG 2010, it works. If you do this with a DWG 2013, it breaks. I'm not sure if it throws an error message or what exactly it does...
Feel free to correct me or post your experience to the thread.
Thanks everyone!
Phil Borycens
6 REPLIES 6
...because ArcGIS can't read 2013-DWGs?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
I concur definetely: in Acad 2013 you'd WBLOCK to an earlier release than itself.
If the source DWG contains Object Data, you can consider _MAPEXPORTing to shapefile, since I doubt Arcgis would be able to understand the embedded OD in a DWG.
Thanks for the feedback, guys. I imagine that ESRI is working to figure out what's different between a 2010 and a 2013 DWG, and likely they are working on a fix on their end.
And yes, Antonio, you're right, there are other ways...
I just had to ask because I don't have ArcGIS here to play with.
Phil Borycens
Murph_Map
in reply to: phil_borycens
Every good AE should have a copy of the competitors software available to them. 🙂
Murph
Supporting the troops daily.
I have questions of my own relating to this thread.  I have a process where my ESRI software reads DWGs directly through an automated process.  Now it does not work with CAD 2013.  I have to save it back to previous release for ArcGIS to read it.  Are there any other workarounds I should be aware of.  I have not seen any patch from ESRI.
For reading object data, the ArcGIS for AutoCAD extension for ArcGIS works but I do not like having to create the DWG from ESRI.
thanks, Jim
trippcor
While I have not heard anything official, I believe Esri is waiting on the release of ArcGIS 10.2 to support 2013 DWGs. The 2013 DWG has been out long enough for them to have figured it out and release a patch for ArcGIS 10 or 10.1 based on past experience. The Data Interoperability Extension for ArcGIS may support the 2013 DWG but I have not tested that.
Tripp Corbin, GISP
eGIS Associates, Inc.
www.egisassociates.com
Tripp Corbin, GISP
CEO
”Boost
