AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Dwg Object Library drawback linked FDO
1 REPLY 1
ripato
873 Views, 1 Reply
I have a dwg object library used in representing a connection with FDO, the downside is that I can not find where it keeps the relationship of the linked objects within the MAP, appreciate someone aid me
1 REPLY 1
phil_borycens
in reply to: ripato
Basically there are two ways that your data might be linked. Since you mention FDO, it's likely that a Join was created between two FDO datasets. You can manage the Join after it has been created. Everything you need to know about this can be found in the help here:
Modifying or Removing Joins
http://docs.autodesk.com/MAP/2013/ENU/filesMAPUSE/GUID-6FD346D6-45FF-45FA-BC87-6C06DDCB97A0.htm
If you are using a link template to link tabular data with AutoCAD geometry + object data, then you can't really modify the existing link template. But you can change the path back to the database and easily Delete Links, create a new Link Template, and Generate Links again. This is spelled out here:
Editing a Link Template
http://docs.autodesk.com/MAP/2013/ENU/filesMAPUSE/GUID-624B0B22-8085-4E98-ADC3-930ABAEFE827.htm
Hope this helps Smiley Happy
Phil Borycens
”Boost
