AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
duplicate points and text
5 REPLIES 5
mugye77
251 Views, 5 Replies
Does anyone have a lisp or any other way to delete duplicate points and text?
-Thanks
Paul Bradford
5 REPLIES 5
in reply to: mugye77
with the express tools there is an "Overkill"
command or in map the map clean-up commands. Look at the help files on the
clean-up command if you don't use it right it can really mess up a
project.
Murph
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Does
-Thanks
Paul Bradford
mugye77
Murph,
I have map 6, and i don't think i have express tools. Where would i find them if i had them. Also will the map cleanup delete duplicate points and text?
-Thanks
Paul
Paul,
If you have the express tools they should be in a
folder in the AutoCAD dir. Yes the drawing clean-up will remove the
dupilcate text/points as long as that option is checked.
Murph
Murph,
text?
-Thanks
Paul
Hi Paul, You can also use the express
tools that were available in the earlier versions of AutoCAD with Map 6,
provided you have a copy of the older version of AutoCAD installed somewhere.
Good luck
Murph,
text?
-Thanks
Paul
The Autodesk Knowledge Base has lisp
routines for deleting duplicate text,
points and blocks and advice on how to
modify the routine if you wish to do so.
Neil Carstairs
Cartographical Surveys Ltd (UK)
”Boost
