AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
drive alias to novell
0 REPLIES 0
Message 1 of 1
stephane.aubertin
311 Views, 0 Replies
Hello
I try to attach a source drawing. I define a alias pointing in a folder in a Novell drive.
After that (with this Alias) I chose a drawing and add it. The drawing appear under Drawings in the map Explorer.
But  I can't do any operations, I error mesasges : it is impossible to read the file and querry object in the file.
If I copy the drawing to a local drive , and I joine it, everything works right .
The only Rights that I don't have in the Novell are Supervisor and Access Control. I Have Read / Erase / mOdify / Write / Create / File Scan.
Is there a way to contact Novell ?
Thank you very much.
Stephane A. Aubertin
Responsable - traitement de l'information (gestion des espaces)
Service de la planification et des projets immobiliers
HEC Montréal
www.hec.ca
0 REPLIES 0
”Boost
