Hey,
I have looked through internet and there is plenty of information about draping, but i still cant seem to make it work. Basically i have a shape file and a TIFF file (tiff file is larger than the shape file, if that makes any difference). What i do, is that first of all i connect the .shp file extension. Then i create 3d surface from the shape file points, using "contour" Z values. 3D surface is created. Then i connect tiff file to drawing. As much as i searched, when i then switch to 3d view, it should pretty much drape the tiff file on surface. But for some reason, it doesent. Is there maybe any extra command to force tiff onto 3d surface or is there maybe something i am missing here?
Thanks in advance.
Henri
my first look will go to
Then I would see a lot of chances to misunderstand the way from SHP to surface. So click onto the "surface" and look in the property-window: what type of object is this geometry?
- alfred -
