AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Draping a 2d polyline onto a 3d surface
3 REPLIES 3
mrgsite
1435 Views, 3 Replies
Hi.  I am wanting to digitize a geology map using AC Map 3d.  When I draw 2d polylines of geology units, I would like to be able to drap these onto a DTM suface so I can have them in 3d.  How do I do this?  Thank you.
-Michelle
3 REPLIES 3
antoniovinci
in reply to: mrgsite
Try _PROJECTGEOMETRY
ChadRoberge
I believe you have to have your polylines set up as an FDO along with your DEM.  PLace the polyline layer over the DEM layer and click the 3D button on the bottom left of your screen.  You should see your DEM and the polylines drapped over it.
antoniovinci
in reply to: ChadRoberge
Unfortunately this is only a "visual" effect, because no physical 3Dpoly is created...
”Boost
