AutoCAD Map 3D General Discussion
Active Member
0 Kudos
Post 1 of 4
Draping a 2d polyline onto a 3d surface
857 Views, 3 Replies
03-17-2012 12:18 PM
Hi.  I am wanting to digitize a geology map using AC Map 3d.  When I draw 2d polylines of geology units, I would like to be able to drap these onto a DTM suface so I can have them in 3d.  How do I do this?  Thank you.
-Michelle
194 Kudos
Post 2 of 4
Re: Draping a 2d polyline onto a 3d surface
03-17-2012 03:47 PM in reply to: mrgsite
Try _PROJECTGEOMETRY
Active Contributor
1 Kudo
Post 3 of 4
03-19-2012 10:57 AM in reply to: mrgsite
I believe you have to have your polylines set up as an FDO along with your DEM.  PLace the polyline layer over the DEM layer and click the 3D button on the bottom left of your screen.  You should see your DEM and the polylines drapped over it.
194 Kudos
Post 4 of 4
03-19-2012 11:51 PM in reply to: ChadRoberge
Unfortunately this is only a "visual" effect, because no physical 3Dpoly is created...
