AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
drainage divide
5 REPLIES 5
581 Views, 5 Replies
drainage divide
Does anyone know how to get the drainage divide lines from a layer with contour lines?
Should I use Autodesk Civil 3D instead? How can I do it?
Thank you
5 REPLIES 5
Civil 3D with Watersheds. I think it can be done in Map but will take more prep of the data.
Kevin Clark P.E.
www.inmotioncon.com
Not to be snarky, but I have found it waaaay faster and straight forward to
simple "Read" the contours and place a pline by hand. By the time you finish
muckin' round with Watershed settings et al you would probably have it drawn
in
Civil3D watersheds
wrote in message
news:6260075@discussion.autodesk.com...
contour lines?
Thank you
Hi Kevin, How do you deal with the "drainage notch" and "Flat area"
boundaries created with that? Out Tributary area maps do not typically
included those; (we have a mad scientist that decides where the water wants
to go, for us )
Joe
Check your shp file resources from states, counties, towns, etc. many have
watershed files available.
dave
"Joe Bouza" wrote in message
news:6264823@discussion.autodesk.com...
to go, for us )
Joe
”Boost
