AutoCAD Map 3D General Discussion
Active Contributor
27thofnever
Message 1 of 3 (175 Views)
Accepted Solution
Downloadable Help File?
175 Views, 2 Replies
09-16-2013 12:05 PM
Is there a way to download the Map 3D 2013 help file?  A user has a computer that can't, for security reasons, be  connected to the internet.
Thank you!
philip.s
Message 2 of 3 (162 Views)
Re: Downloadable Help File?
09-16-2013 12:58 PM in reply to: 27thofnever
Welcome to the community Jason!
I'm not sure if this is relevant to Map 3D, but on other AutoCAD verticals you can go to Options -> System tab -> and uncheck "Access online content when available", which will then cause the in-product help to look on the local drive for help content.
The specific location of the local content can be found and consequently opened from the Options -> Files tab.
Can you let me know if that works?
Philip Schmelzer
Active Contributor
27thofnever
Message 3 of 3 (153 Views)
09-16-2013 01:27 PM in reply to: philip.s
Thank you, sir!  I believe that will work perfectly.
Announcements
Need installation help?
