AutoCAD Map 3D General Discussion
Active Contributor
ABielecki
Message 1 of 6 (190 Views)
Double FDO style
190 Views, 5 Replies
11-12-2013 12:17 AM
I have some problem with double styles in some files which are connected by FDO.
I want to make two special rules for every area. For example:
I have in table two different kolumns (atributies) - function and density. I want to have visible solid fulfilment in different colors with function and hatched this some areas with density eighter. Bouth styles should be visible in the same time. Is it posiible in AutoCAD Map?
GIS
Active Contributor
maherich
Message 2 of 6 (187 Views)
Re: Double FDO style
11-12-2013 01:12 AM in reply to: ABielecki
there are 2 possibilities:
1. prepare special style for all the combinations of function and density. Each style will consist of at least fills solid and hatch.
2. add the FDO layer twice into display model. stzle each layer according to one of the attributes. set the proper order of display so that hatch come over the solid.
Martin
Active Contributor
ABielecki
Message 3 of 6 (171 Views)
11-12-2013 03:00 AM in reply to: maherich
Good Idea!
This was my aim:smileyhappy:
GIS
Valued Mentor
parkr4st
Message 4 of 6 (147 Views)
11-12-2013 11:38 AM in reply to: ABielecki
another option if you can theme related to the combo of the two fields is to concatenate them with a calculation and theme on the calculation field.  You add two fills top one for hatch lower one is solid to add variation to the theming
Dave
Active Contributor
ABielecki
Message 5 of 6 (138 Views)
11-12-2013 11:40 PM in reply to: parkr4st
I'm not sure that you're right. When I make two themes, than the higher one is more important than the lower one and solid styl isn't visible at all (it seems like hatching isn't transparent). I thnk that two themes are preclusive and the higher are current and the lower isn't active at all.
Am I right?
Previous answer is good for my needs.
GIS
Valued Mentor
parkr4st
Message 6 of 6 (131 Views)
11-13-2013 02:54 AM in reply to: ABielecki
I agree that in your case the two layers presents the informaton the best.  Making sure the legend explains the theming well is always a challenge to me.
concat usage   I've attached a sample.  Uses ME83-WF CS.
good luck with your project
Dave
