AutoCAD Map 3D General Discussion
Distinguished Contributor
JohnPM
Message 1 of 8 (256 Views)
Display order shp files
256 Views, 7 Replies
11-27-2012 09:20 AM
I have several shp files ordered in the display manager. Three Polygons, one line and one point shp. the problem is that the bottom polygon that is supposed to draw order last continues to show up above all other files during plotting to PDF or other digital file. I have tried to disconnect and reconnect the problem shp, reorder several times but nothing changes. This is making it impossible for me to plot a file in the way is it being displayed.
John
Murph
Message 2 of 8 (243 Views)
Re: Display order shp files
11-27-2012 04:21 PM in reply to: JohnPM
Try to toggle the "plot paperspace last" radio buttion in the plot dialog.  (?) Just a guess on my behalf.
Murph
Supportting the troops daily.
antoniovinci
Message 3 of 8 (233 Views)
11-27-2012 11:59 PM in reply to: JohnPM
You can override the Display Manager stack, by means of this nice lisp, sir.
JohnPM
Message 4 of 8 (216 Views)
11-28-2012 11:59 AM in reply to: JohnPM
I Could not find a solution and can not spend any more time troubleshooting the problem.   I got it to work once through disconnecting all objects and reconnecing in the order I wanted them to display. However, when I went to theme them the problem returned.  service pack 1 was installed prior.
John
antoniovinci
Message 5 of 8 (205 Views)
11-28-2012 11:24 PM in reply to: JohnPM
I guess you didn't try the above lisp, which physically reorders the layers' stack, sir...
Murph
Message 6 of 8 (198 Views)
11-29-2012 04:18 AM in reply to: antoniovinci
You old LISP does not work with FDO features, FDO display does not use the AutoCAD layers table like you would think.
Murph
JohnPM
Message 7 of 8 (184 Views)
11-29-2012 08:46 AM in reply to: JohnPM
I Appreciate thefeedback on the display order problem and I also contacted support which recommended REGEN and display ordering. Tried both of those without success. Ended up using an oldschool workaround by attaching the trouble shp as dwg and query..alterprops..hatch..draworder for the same results.. If I find the cause I will post back.
John
Active Contributor
KrakowiAneczka
Message 8 of 8 (161 Views)
11-30-2012 01:44 AM in reply to: JohnPM
I had the same problem, resolved by changing the draw order in Groups and in Draw Order from Task Pan, than right click on the shape/sdf and Refresh Layer (try all, the one you want to have on top refreshing the last), if that does not work than: MAPUPDATEMAP
Ania
