I have to add a style text in a display manager. When i add it, i have a option to scale this text. It is possible to have possibility to scale the text as a same height in multiple viewport in a layout... example (* 10 (VIEWPORTSCALE))
but this line does'n work
Thanks a lot for your help
Ghys
Solved by GhyslainBaril2008. Go to Solution.
if the text is set in the style under "size context" to device space, it will autoscale. if "map space" it will be fixed size.
Are you working with FDO (data connect) text ot AutoCAD Text/Mtext objects? If it's autocad text/mtext then you need to use annonation text/scales, I was only able to get the (* 10 (VIEWPORTSCALE)) example to work with points/blocks and not on text objects. Aslo that only worked (AFAIK) in the model tab and is based on the zoom scale more than the View port scales.
no i m workin in the paperspace and the text display whit the displaymanager from a objectdata in the modelspace. I wnat to have 2 viewport in the paperspace and i want to have the text display same height
thanks a lot for new way to the solution
I have find a way for my problem. I'm add the scaleview number in a field of my table attach to the object data. When i display text, the text size multiple de number have in the case scale of my object data. I's work properly.
Thanks a lot
