AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Disappearing features in viewport
2 REPLIES 2
Vasily_BC
253 Views, 2 Replies
Is there any limitation for viewport rotation with connected features?
I have number of connected shapefiles that I can see in model view.
However, my paperspace viewport rotated for 70 degree can't show them.
How to fix it?
2 REPLIES 2
Murph_Map
in reply to: Vasily_BC
This has been a know issue for a while. The best solution is 1, Don't roate viewports,2, keep the number of viewports to a minimum, 3, export the map to Autocad dwg then use viewports/layouts.
Murph
Supporting the troops daily.
Vasily_BC
in reply to: Murph_Map
Hi Murph,
I've played around viewport rotation and found that it's more about scale of a viewport than its angle.
Cheers,
Vasily
”Boost
