Hello, colleagues1
How can I change direction of a line feature? Have any redy default command to do it?
Solved by Alfred.NESWADBA. Go to Solution.
if your "line feature" is of type Polyline you can use command _REVERSE
If your "line feature" is based on an FDO-linked datasource you can select the geoemtry-object ==> right-click ==> and there you also find a point in the context menu like "pline-modify" with the option of reversing the geometry object.
At least with Map3D2013 it does work in that way. If you don't find the option then let us know what Map3D-version your are working with.
- alfred -
I am working in AutoCAD Map 2013, but i din't find commant which you sad.....
if you select the entity, what object-type is it? (what does the property-window show)
- alfred -
I have created a liner feature object (sdf file) connected by FDO and created new fature. When I select the feature and press right click, among of the command I dinn't find reverce command.
Please look at my context menu : Context menu
sorry, the resolution of the screenshot is so small so I can't read your options.
Look to my video, maybe (hopefully) this is a help.
BTW: just saw that the option for pline-modifying only appears in the context-menu if the object is checked-in.
- alfred -
alfred.neswadba, thank you for the video. But that command in context-menu in you video, I could't find in my AutoCAD Map. Is it additional programm to AutoCAD Map?
No, plain AutoCAD Map3D 2013
Have you tried first to check-in the feature and then select it and right-click?
Verify the options if your Map3D is set to automatically check-out features or not. Toggle this option just for a try.
BTW: just tried: the command _PEDIT should also work on FDO-features, so try the option _REVERSE of the _PEDIT command.
@Autodesk: why does _PEDIT ==> _REVERSE work on that type of objects and the command _REVERSE does not? Makes no sense for me.
- alfred -
