AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Dimensions changing when i print
2 REPLIES 2
284 Views, 2 Replies
Need some help
Recently started using AutoCAD Map 3D 2015 and for the most part it is running fine. On a few occassion I have noticed that when i have printed dimensions (linear, aligned and angled) have changed values once i have printed (PDF creator). Does anyone a reason for this. Linear and aligned have just changed from say 12.5 to 0 with dimension lines etc not moving, where angular dimenions changing from 89d14'33" to i assumed the decimal angle with a d at the end. All dimensions are in paper space and and its only the random few not all dimensions on the drawing are affected...
im confused
Andrew
2 REPLIES 2
braudpat
Hello
Welcome to the Autodesk/AutoCAD Forums !
Q1) Please could test again after opening your drawing in RECOVER Mode ?
Q2) Could you test using the "DWG to PDF.pc3" driver and not "PDF Creator", same problem ?
Q3) Have you installed the SP 2 for MAP 2015 ?
http://knowledge.autodesk.com/support/autocad-map-3d/downloads/caas/downloads/content/autodesk-autoc...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Murph_Map
Sounds like it is replacing the text font, try printing to paper or dwg to dwf and see if it happens. Also if you print it twice is the same text changed or is it different text each time?
Murph
Supporting the troops daily.
”Boost
