AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
different properties for points on different layers?
2 REPLIES 2
233 Views, 2 Replies
Dear fellow users, I am quite new to this so please forgive me and correct me if I do this wrong.
I have imported several sets of data points into a drawing, using a script and the commands MULTIPLE POINTS. Each data set is on its own layer and has its own color. Now I would like for each data set to have its own size and shape for the points, as well as its own color. But every time I change the shape (PDMODE and PDSIZE) for points on one layer (using the menu commands Format -> Point style or any other method), the shapes for the points on the other layers change, too, no matter if the other layers are locked.
The next question is, am I in the right place to be posting this question? This must be a question that someone else has posted somewhere, perhaps I could seach an archive of questions somewhere rather than asking you good people to repeat an explanation you have already made?
eliza
2 REPLIES 2
PDMODE and PDSIZE act on the entire drawing.
You can control the colors independently but that
is all.
To do what you want you will need to use
blocks.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Dear
do this wrong.
eliza
Thank you! That helps a lot.
”Boost
