AutoCAD Map 3D General Discussion
0 Kudos
Post 1 of 3
DEM - assign coordinate system
325 Views, 2 Replies
08-15-2012 12:34 PM
I'm using Map3D & Raster Design 2012.
I have connected to some SRTM DEM data, but the resulting terrain and contours I generated are not showing properly. Specifically, the map area is stretched out of shape (too wide L & R). I seem to recall it had to do with setting the proper "define coordinate system" option for the file.
Can anyone provide me with any help on what to assign, or if I'm off the mark altogether?
Thanks in adavnce for the help.
196 Kudos
Post 2 of 3
Re: DEM - assign coordinate system
08-16-2012 12:04 AM in reply to: directapproach
I fear you can't transform DEM files on-the-fly, sir.
Try to set the main CRS of your drawing (command _ADESETCRDSYS) identically to which you read in the Dem header (I bet LL84) then _MAPCONNECT the SRTM stuff again.
Product Support
11 Kudos
Post 3 of 3
01-03-2014 03:17 PM in reply to: directapproach
In the 2014 release, this issue no longer exists. The recommended workflow is:
1. Run MAPCSASSIGN and assign the drawing a coordinate system.
2. Data Connect to the DEM and Add to Map.
Phil Borycens
