Hi!
Does anyone know how I can delete/remove a vertex from a map feature? I have a shapefile that I have connected to and I need to alter some of the geometry of a few of the parcels. I can move the vertices around and delete the entire feature, and check in and out with no problem... However I cannot delete or remove an unwanted vertex. I am kind of new to this...
Thanks!
not sure if this is dependent on your map version. I use Map 2012 and can modify a feature similar to modifying a pline using pedit. I can insert a new vertex and delete an existing one.
As I don't have the english version - I click on the SHP feature (polygon) and open the context menu which has an option called "modifying polygon" (or something similar in english). Via this options I have further options such as "modify vertexes" which includes "insert" and "line". "Line" is for removing - have a look at AutoCAD PEDIT command. LINE option there works the same as here.
Rob
select the feature, grab the point you want to delete, drag and drop on an adjacent point & check in
dave
