AutoCAD Map 3D General Discussion
New Member
cbarnes1
Message 1 of 7 (1,722 Views)
Delete Unreferenced & Not Found Excel Xref
1722 Views, 6 Replies
01-26-2012 11:55 AM
I copied and pasted special part of an excel document into AutoCAD Map 3D. But I had deleted it instead of detaching it. How do I remove it? Its says I cannot reload, detach or bind. I have 6 of those. I have 2 more that are Not Found and states the same thing. I just want them gone. How do I do it?
Member
mike17
Message 2 of 7 (1,690 Views)
Re: Delete Unreferenced & Not Found Excel Xref
02-03-2012 08:16 PM in reply to: cbarnes1
Try deleting the data link in the data link manager
New Member
cbarnes1
Message 3 of 7 (1,675 Views)
02-06-2012 05:11 AM in reply to: cbarnes1
Yeah, I had finally figured that one out. I failed to delete or give solution to this discussion once I had found it. Thanks though!
New Member
demistephane
Message 4 of 7 (1,457 Views)
09-12-2012 08:50 PM in reply to: cbarnes1
the most accurate and the best straight answer ... BULLSEYE!
New Member
GregPenny
Message 5 of 7 (939 Views)
08-07-2013 01:43 PM in reply to: cbarnes1
I am trying to remove a listed data link that appears in the xref manager dialogue box. Because it has an "Unreferenced" status, (the original data link was erased from the drawing and then the drawing was purged) the name still remains and the data link is not listed in the data link manager.
So, I cannot remove the data link reference in either the xref manager or the data link manager dialogue boxes. Does anyone have a solution on how to remove the reference in the xref manager dialogue box when the same data link (which doesn't exist physically in the drawing file) isn't listed in the data link dialogue box as well?
I am completely stumped!
Member
mike17
Message 6 of 7 (932 Views)
08-07-2013 02:02 PM in reply to: GregPenny
perhaps if you post the drawing...
New Member
GregPenny
Message 7 of 7 (929 Views)
08-07-2013 02:21 PM in reply to: mike17
Wow. Apparently the specific file in question lost the "Unreferenced " data links once it was closed and then reopened!
They are gone now. It's the wierdest thing because I know I saw them there before.
Sorry to bug you.
