Carlos,
You can join a DBF to a shapefile as long as you have key fields to join to. You have to set the DBF file as an ODBC source, then connect to that ODBC source in Map. Then it will be available in the join tool.
Here's an example of how to set up the DBF as an ODBC source - just go up to step #3 using your filenames and paths:
http://www.etbsolutions.com/library/Goldmine/ODBC_GM.htm
Rick
http://www.cadsoft-consult.com/blogs/geo/
Edited by: rick-chappell on Mar 26, 2010 12:22 PM
Edited by: rick-chappell on Mar 26, 2010 12:24 PM
