AutoCAD Map 3D General Discussion
Member
bmilks
Message 1 of 9 (278 Views)
Database and Drawing edits at same time
278 Views, 8 Replies
03-12-2012 08:40 AM
Can you have a database and the dwg file open at the same time and not be in read-only mode?
For example: I have access database file open and editting it while in the dwg file with the graphical info that is linked to the database.
I'm running Map 2012, and have an AccessDatabase attached.  I'm able to edit the tables in either Map or Access and have the changes show up immediately in both places with no problems.
Lorrie
Active Contributor
foxeec
Message 2 of 9 (243 Views)
Re: Database and Drawing edits at same time
03-13-2012 07:42 AM in reply to: bmilks
Lorrie
Active Contributor
foxeec
Message 3 of 9 (238 Views)
03-13-2012 07:44 AM in reply to: bmilks
btw,
When i say my Access database is 'attached', I mean I've attached it via Link Template on the Map Explorer Tab, not  through FDO.
Lorrie
Member
bmilks
Message 4 of 9 (236 Views)
03-13-2012 07:46 AM in reply to: foxeec
Thank you for your help, just what i needed!
Member
bmilks
Message 5 of 9 (197 Views)
03-19-2012 08:46 AM in reply to: foxeec
Do you have a problem of Map being a 64-bit installation, but office 2010 being 32-bit?  We seem to be having problems on that end now.
Active Contributor
foxeec
Message 6 of 9 (192 Views)
03-19-2012 02:31 PM in reply to: bmilks
i don't seem to have that problem.  my Access is 2010, however, it is saved to version 2000.  Maybe that's why it works.  Also, just to reiterate, it is connected through the 'map explorer' tab, under data sources.  i do NOT attach through FDO on the 'display manager' tab.
Lorrie
Member
bmilks
Message 7 of 9 (184 Views)
03-20-2012 05:27 AM in reply to: foxeec
We have it all worked out now, thanks again for the help.
Member
bmilks
Message 8 of 9 (174 Views)
03-20-2012 08:32 AM in reply to: foxeec
Sorry to bother you again, but the tech that is doing this just informed he wa using am FDO...which is why I keep having obstacles.How exactly do I define a link template and use it with features, not just objects?
Is there somewhere that spells this out maybe step-by-step or similar?
I really do appreciate the help you have been giving thus far too.
Active Contributor
foxeec
Message 9 of 9 (167 Views)
03-20-2012 11:16 AM in reply to: bmilks
how i attach:
1.  right-click on Data Source, on the map explorer pane and choose 'Configure'
2.  Name it.  This can be any name, as long as you know what its for.
3.  You'll get a dialog box to set up the connection.  i use the Microsoft Provider for ODBC Drivers, then hit 'next'.
4.  you should have a number 1, which asks you to specify the source of data.  i use data source name, and on the drop down menu, choose MS Accesss Database.
5.   hit ok.
6.   right-click again on the Data Source and choose 'attach'.  you should have a dialoog box come up and you choose the name you entered in the steps above.  then you can browse to your Access database.
At this point, right-click on Link Template and select 'Define Link Template'. You choose the table and create a primary key and name the link template.
In order to link your drawing data, use 'mapod2ase' select the OD Table, choose to link OD to database, and select the link template to use, select objects, then select 'proceed'.  This links drawing objects to the database.
This does NOT work in connection to FDO features (that i am aware of), only CAD objects.
More helpful?
Lorrie
