AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Data Extraction to labels
7 REPLIES 7
Message 1 of 8
tim.ferreira.cld
874 Views, 7 Replies
Can anyone help with this problem:
I have been able to successfully extract object data from imported shape file (basin delineations with basin NAMES, etc..).
I have been successful to create labels (from the NAME attribute) that display just fine as long as i'm in Civil/Map3D.  However, if i open the file in straight autocad (that the rest of the office uses) there are no labels.  I can't simply copy them to another file, they are not copyable.
Help?
Thank you for your time!
7 REPLIES 7
Message 2 of 8
braudpat
in reply to: tim.ferreira.cld
Hello from France
Welcome to the Autodesk/AutoCAD Forums !
So you have a FDO drawing with many FDO layers (and FDO labels) ...
If you want to get standard DWG, you must "Export/Save the FDO Map as DWG"
At the Top-Right of the Map Navigator, you have an Icon named "Maps" (maybe) !?
So CLICK on it then Right Button then "Export/Save the FDO Map as DWG" ...
And you will get a standard DWG with one layer for each FDO Layer ON
Do you see that I mean ?
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 3 of 8
I am starting with a .dwg - i imported shape file into Autocad Map3D 2013.  I have polyline regions that have data attached to them.  I can display these "attribures" within Map3D but want to "export" these so I can use labels, or so they can appear (in the center of each polyline region) in regular autocad (non-Map3D/non-Civil3D).
not sure what software you thought i was working from?  What is a FDO?
Thanks for your reply.
Message 4 of 8
Annotation template make the job by creating a bloc with attributes which are filled with choosen informations form the objet (properties or OD)
Olivier
Message 5 of 8
braudpat
Hello
So the question is : are you using FDO features of MAP ?
Please use the command : MAPCONNECT ...
Have you already use this command to connect "directly" to GIS Data with SHP, SDF, SQLite, PostGIS, Oracle, etc FDO Drivers ?
Patrice BRAUD
Message 6 of 8
Thank you Olivier, that was the answer.  Thanks for your time.
Message 7 of 8
tim.ferreira.cld
in reply to: braudpat
Thank you braudpat, those were helpful tips for future tasks involving data connection/extraction.
Message 8 of 8
braudpat
Hello from France
Sorry for my "bad" answer (I thought you were using FDO features !) about your problem !
Olivier (an other Frenchie, I know him ...) understood well your question/problem ...
Good Luck
Patrice BRAUD
”Boost
