AutoCAD Map 3D General Discussion
New Member
0 Kudos
Post 1 of 3
Dashed lines become continous in curves - is there a system setting?
799 Views, 2 Replies
08-20-2012 11:57 PM
Hello!
I am having trouble presenting segmented lines with a dashed line type in AutoCadMap 3D 2011. When the segments are small (as in curves) the dashes float together and the lines appear to be continous. This is not the case in for example TopoCad and ArcGIS.
Is there some kind of system setting in AutoCad where you can chose drawing technique? So that the dashed line segment starts with the blank part instead of the dashed?
Kristina Danielsson
two options to check that:
  • one is to verify the settings LSCALE, PSLTSCALE and MSLTSCAE, these define how the scaling of the linetype is, the last to ones also depending on the viewport-scale (plot-scale).
  • the second may be for polylines if the vertices are to close together (for the spacing-distance of the linetpe). For that each polyline has the property Ltype-Gen (>>>click<<<).
- alfred -
1,210 Kudos
Post 2 of 3
Re: Dashed lines become continous in curves - is there a system setting?
08-21-2012 12:47 AM in reply to: kristina.danielsson
- alfred -
Alfred NESWADBA
New Member
0 Kudos
Post 3 of 3
08-21-2012 02:56 AM in reply to: kristina.danielsson
Thankyou so much for your help.
Your second suggestion - setting of parameter ltypegen seems to be exactly what I was looking for!
My polylines now look exactly like I want yhem to look.
Once again thankyou.
Regards
Kristina
