AutoCAD Map 3D General Discussion
Member
lwhittemore
Message 1 of 2 (173 Views)
CUI custom buttons
173 Views, 1 Replies
10-24-2012 10:28 AM
I am trying to make some custom buttons to change some text to a different layer and then change the text height.
I cannot figure out the command line alias for "Text Height" to enter it into the macro.
I have tried the "scaletext" command but I cannot figure out how to add this command to the "Chprop" command on the macro line.   The command seems to stop before performing both actions.  What am I missing?  Here is the button macro so far        ^C^Cchprop;la;GasAban;c;g;;scaletext;c;s;12;;
(Gas Aban is the layer name I am using)
Product Support
phil_borycens
Message 2 of 2 (137 Views)
Re: CUI custom buttons
10-26-2012 09:39 AM in reply to: lwhittemore
What you are doing might be possible in the CUI, but reading through your process, it sounds like it might be better suited for a LISP routine. You can post to the customization forum here if you need support on this.
In AutoCAD Map 3D, there is also the Workflow Designer. You can create a new workflow by running the MAPWORKFLOWCREATE command. This is mainly for geospatial workflows, and you description leads me to believe that you are just working with standard AutoCAD objects, so I'm not sure if this will apply to you.
Phil Borycens
