AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Crosshair jumps away for a split second in MAP 5
1 REPLY 1
164 Views, 1 Reply
In MAP 5 only, we have a problem where the crosshair moves to another
position on the screen for a split second and then back again. This happens
with different commands on different computers. Generally commands like
move copy and erase. It only happens on computers with faster than 1.4GHz
and with different types of graphics card.
Thank you
Andreas
av@computersupport.itgo.com
http://computersupport.itgo.com
1 REPLY 1
I sometimes have a similiar problem when I use "linkmanager" in Map 5. The
pickbox gets stuck on the edge of the drawing editor. The command works, but
without the pickbox it is impossible to tell which item you selected. It is
resolved by cancelling the command, then rerunning it. Go figure?
"Andreas V" wrote in message
news:E23D322B8CADC5096A42B401BAAF162B@in.WebX.maYIadrTaRb...
happens
> Thank you
> Andreas
”Boost
