All toggles are turned off and the cursor jumps all over the screen when zoomed in. Also, there are two rectangular boxes in the northeast quadrant of the crosshairs when moving near a point or node. How to eliminate this? All function keys are off.
Solved by Alfred.NESWADBA. Go to Solution.
look into >>>this thread<<< for handling SELECTIONCYCLING,
Am I right? If yes ==> you have not turned of all toggles 😉
- alfred -
The toggles were off, but the SELECTIONCYCLING was set as<2>. Don't know how that happened. Thanks much for the solution.
