Is there a way to crop an aerial image that is loaded by connecting to a WMS server?
Is there also a way to save that image after cropping to a JPG or TIF?
WMS data is only updated for the visible area, so the smaller the zoom-value is the smaller the WMS-data is updatet.
You can use the plot-function to a raster-printer therefor.
HTH, - alfred -
You can easy crop a WMS imagery, by means of the opensource Qgis:
As you can see in the attached file, you'll get a clipped Geotiff, with alpha channel.
In Autocad, _MAPIINSERT then set TRANSPARENCY=ON in the image properties.
I'm pretty sure this procedure would create the same issue we have now. The licensing agreement for the imagery we have access to only allows it to be used in the software you bring it into. Once you bring it into a software program such as the one you mentioned, you can't clip part of the imagery and then bring it into another software package such as AutoCAD. I am going to check it out though to make sure.
Thanks for the input.
Mike
You can only do with data onnection rasters "Resample Raster" right clicking. I wrote about cropping and clippint to the wish list.
I have only used to crop images with the help of following code:
Private Sub button1_Click(sender As Object, e As EventArgs)
Dim folderName As String = "c:/YGPic.bmp"
Dim ygPic As YGpic = YGFolder.LoadImageFolder(folderName)
ImageManipulating.ApplyImageCropping(ygPic, 50, 60, 200, 300)
YGFolder.StoreImageFolder(ygPic, "c:/ygpic.bmp", New BMPCreator())
End Sub
I hope it helps. Good luck.
Best regrads,
Arron
arronlee wrote:
I have only used to crop imageswith the help of following code
Sir, thanks for your effort, but we're talkin' about georeferenced images, not "simple" bitmaps...
Hi, I am getting more frequently into this situation and a resolution is still not at hand.
Guru guys out there...will appreciate very much for a solution.
Thanks.
Ed
My solution is still the same, sir, but actual Qgis release allows you to set the output density, e.g. 1 meter/pixel.
9 Years later, I have exact same requrement and found this.
I wish we had got a solution about this topic without having to use a 3rd party software like QGIS since C3D/Map 3D had already setup a connection of WMS/WMTS.
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
Hi @TiStars
Of course there's a way, but you can't call it CROPPING an image.
Yes, it achieves the same thing as a CROPPED image because it limits the WMS to small area, an area that's defined by you, and doesn't display WMS data that's outside your area.
BTW, it's better to start a brand new post with a brand new title, than to piggyback onto an existing one. Burying your question in an old post only temporarily bumps it up (until another post moves your bumped-up post downward) and gives the impression no solution has been found since the OP's original post.
Unfortunately, mentioning 'cropping' will limit the responses since readers will automatically assume the issue can only be solved by utilizing some form of cropping A more productive approach is to provide the data you have then explain the end result you desire. It's not really necessary to mention a method which must be, or should be, used to get there.
Trust the forum, if there's a way, another tool (and there is), someone in the forum will (or has) figured it out.
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
