AutoCAD Map 3D General Discussion
5 Kudos
Post 1 of 9
Crop WMS image
1063 Views, 8 Replies
10-16-2012 09:01 AM
Is there a way to crop an aerial image that is loaded by connecting to a WMS server?
Is there also a way to save that image after cropping to a JPG or TIF?
Mike Porter
www.ppeng.com
Civil3D 2014 SP2
Win 7 Professional - 64-bit
HP Z230
Xeon 3.20Ghz
24GB of RAM
Nvidia GeForce GTX 760
1,219 Kudos
Post 2 of 9
Re: Crop WMS image
10-16-2012 11:04 AM in reply to: mikepo
WMS data is only updated for the visible area, so the smaller the zoom-value is the smaller the WMS-data is updatet.
You can use the plot-function to a raster-printer therefor.
HTH, - alfred -
Alfred NESWADBA
196 Kudos
Post 3 of 9
Re: Crop WMS image
10-26-2012 04:56 AM in reply to: mikepo
You can easy crop a WMS imagery, by means of the opensource Qgis:
  1. load it
  2. save all as Geotiff
  3. unload the WMS layer, and open the Geotiff
  4. clip by a vector boundary, setting "No data" for the outside stuff.
As you can see in the attached file, you'll get a clipped Geotiff, with alpha channel.
In Autocad, _MAPIINSERT then set TRANSPARENCY=ON in the image properties.
5 Kudos
Post 4 of 9
Re: Crop WMS image
10-26-2012 07:56 AM in reply to: antoniovinci
I'm pretty sure this procedure would create the same issue we have now. The licensing agreement for the imagery we have access to only allows it to be used in the software you bring it into. Once you bring it into a software program such as the one you mentioned, you can't clip part of the imagery and then bring it into another software package such as AutoCAD. I am going to check it out though to make sure.
Thanks for the input.
Mike
Mike Porter
www.ppeng.com
Civil3D 2014 SP2
HP Z230
Xeon 3.20Ghz
24GB of RAM
Distinguished Contributor
9 Kudos
Post 5 of 9
Re: Crop WMS image
10-26-2012 11:22 AM in reply to: mikepo
You can only do with data onnection rasters "Resample Raster" right clicking. I wrote about cropping and clippint to the wish list.
Binnat Khalilov
Active Contributor
0 Kudos
Post 6 of 9
Re: Crop WMS image
04-10-2014 12:25 AM in reply to: mikepo
I have only used to crop images with the help of following code:
Private Sub button1_Click(sender As Object, e As EventArgs)
Dim folderName As String = "c:/YGPic.bmp"
Dim ygPic As YGpic = YGFolder.LoadImageFolder(folderName)
ImageManipulating.ApplyImageCropping(ygPic, 50, 60, 200, 300)
YGFolder.StoreImageFolder(ygPic, "c:/ygpic.bmp", New BMPCreator())
End Sub
I hope it helps. Good luck.
Best regrads,
Arron
196 Kudos
Post 7 of 9
Re: Crop WMS image
04-10-2014 03:28 AM in reply to: arronlee
arronlee wrote:
I have only used to crop imageswith the help of following code
Sir, thanks for your effort, but we're talkin' about georeferenced images, not "simple" bitmaps...
Active Member
1 Kudo
Post 8 of 9
Re: Crop WMS image
08-28-2014 05:24 PM in reply to: mikepo
Hi, I am getting more frequently into this situation and a resolution is still not at hand.
Guru guys out there...will appreciate very much for a solution.
Thanks.
Ed
196 Kudos
Post 9 of 9
Re: Crop WMS image
08-28-2014 10:47 PM in reply to: Edwin
My solution is still the same, sir, but actual Qgis release allows you to set the output density, e.g. 1 meter/pixel.
