You have to define an object data table for your text values first. Then
populate the object data table by automatically generating links to your
text. Once the text linked to the data table, the data field will be
appended to your topology table and the values from the data will be there
as well.
"Bostjan Cotic" wrote in message
news:C83C35F09C8995A5AD3D3A50E74D90D9@in.WebX.maYIadrTaRb...
> Hi,
> Thank you for you time, to answer.
> But, the focus of my problem is, how to put the value of the text inside
the
> Topology table. Now I have 4 fields:
> id
> area,
> perimeter and
> links quantity
> But is there any way, that I could get inside the table, the value of the
> text, in this case used as a centroid. For example F for forrest.
> Sincerely
> Bostjan Cotic
> > When defining your topology, you have 3 elements, Centroids, Links, and
> > Polygons. Use your linework for the polygons, and select the text
elements
> > for your centroids. The text will then become centroids.
> > news:726C537EC2EF9B52A8BFB53FA2F9110B@in.WebX.maYIadrTaRb...
> > > hello,
> > > I have a specific problem.
> > > I work on a project to transfer a paper-based master plan in a digital
> > form.
> > > We digitized it allready and put a normal dtext letter inside areas to
> > mark
> > > the land-use.
> > > Is there any elegant way to create a Polygon Topology, that would
> include
> > > this letter in a table (to take it as a centroid)?
> > > Or any other way, the mail goal is to export this land use to an
ArcView
> > > format.
> > > Thanks!
> > > Bostjan
