AutoCAD Map 3D General Discussion
Member
0 Kudos
Post 1 of 10
Creating Contours From .txt file data
655 Views, 9 Replies
03-03-2013 12:46 PM
I have been trying to create a contour map from survey data my group collected for a project but have not had much luck. I have all of the data in a text file (that is set up correctly) with the northings, eastings and elevations. I can get that to import the points and it is correct but I cannot get the contour lines to draw. I need the intervals to be .25ft with a major line every 4. there is about 1600 different data points.
Can anyone help me out with the proper steps to create them from a text file? To get the points in the file i used "_MAPIMPORT"
also, the data is in an L shape so can someone also explain how to create a boundary condition to only contour that L shape and not try to connect points on opposite ends of the area?
194 Kudos
Post 2 of 10
Re: Creating Contours From .txt file data
03-03-2013 10:30 PM in reply to: foskeyj
Without Civil, you won't create contours limited by a boundary...
If you zip and attach that point Ascii file, I'd try to generate them in a Gis opensource (for free, sir).
Moderator
51 Kudos
Post 3 of 10
03-04-2013 01:05 AM in reply to: foskeyj
foskeyj,
copy this example  to the COMMANDLINE :smileyhappy:
_pline
96.5293,114.8268
117.3895,187.8088
192.0914,190.0631
215.7705,172.3107
246.7788,161.0394
269.3303,211.4787
287.3716,214.8601
331.9108,192.8809
347.4150,164.1390
348.8244,126.6618
348.5425,103.5555
274.6863,92.8477
248.4702,108.3458
231.2747,104.1191
214.0791,89.4663
194 Kudos
Post 4 of 10
03-04-2013 02:09 AM in reply to: Olga_Shevchenko
It doesn't matter, madame.
A contour is NOT a random chain, but a 2D polyline having nodes at the same identical Z elevation.
The only solution is to create a Dem file from that point cloud, then extract the desired contours.
Autocad Civil does it in a while, Map > 2007 doesn't, period.
36 Kudos
Post 5 of 10
03-04-2013 04:54 AM in reply to: antoniovinci
if you've successfully loaded file into POINT in AutoCAD, you can use MAPCREATESURFACE to generate a TIF (DEM) then with Right clic on DEM you can create contours lines from DEM (in SDF file) followed by MAPIMORT to obtain AutoCAD Polyligne. Eventually, MAPCLEAN to simplify if polyline has too much vertex.
If you want polyine with elevation, it's necessary to request your DWG, to affect (modify properties)  ELEVATION form Elevation read in OD.
It's not a really a nice TIN (like Civil can do) but it can be enough for your job.
Olivier
194 Kudos
Post 6 of 10
03-04-2013 06:03 AM in reply to: olivier.eckmann
In my Map2006, the MAPCREATESURFACE command creates a vector Tin, not a raster Dem.
So I apologize deeply, gentlemen.
Member
0 Kudos
Post 7 of 10
03-04-2013 08:56 AM in reply to: olivier.eckmann
thank you to everyone that helped out. Funny enough, right after i posted my question i determined how to do it. I know how to do it in Civil 3D but for some reason it crashes after about 5 minutes (64bit windows 8) so that program is starting to become useless for me.
1,211 Kudos
Post 8 of 10
03-04-2013 11:07 AM in reply to: foskeyj
SCNR1: So it would have been great to let the forum know that as there are now some people spent time for your problem while you have already solved it.
SCNR2: You have chosen the wrong os for the program, so it's not the program, that is useless, you took the wrong combination of os and app that can't be combined (Win8 is not supported for Civil3D ...up to 2013). Take Win7 and the program is more than useful :smileywink:
- alfred -
Alfred NESWADBA
Member
0 Kudos
Post 9 of 10
03-04-2013 11:41 AM in reply to: foskeyj
I could have done that, but i dont sit on the forums when i am trying to do something. My issue was that the file i recieved was incorrectly titled and i was making sure that i had the correct process.
I have 2013 with the 64bit service pack installed. From everything that i have seen, it is supported by 8.
I am stuck with this program to do this project. I am more familiar with microstation which i use at work everyday.
1,211 Kudos
Post 10 of 10
03-04-2013 11:45 AM in reply to: foskeyj
Sorry, no, Civil3D 2013 is not supported for Win8, and I guess that is not written anywhere that is should be, or do you have a link for such an info?
>>>click<<<
- alfred -
Alfred NESWADBA
