AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Creating and using dwg seed file
3 REPLIES 3
1672 Views, 3 Replies
I am looking to attach custom attributes to autocad features (lines, polylines, polygons, points) so that when we insert the dwg into ArcGIS the attrubutes are linked to the feature in both autodesk and gis. I am thinking a dwg seed file will perform this task but am looking for some help understanding and implementing the procedures.
3 REPLIES 3
Alfred.NESWADBA
Can be done with "object data" (>>>details<<<).
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
antoniovinci
As far as I know, the DWG format with OD is not fully readable by ARCxxx, i.e. you can transfer the only geometry.
Why don't you simply use the shapefile as normal interchange format between cad and gis..?
Thank you, you are fully right, I missed the point that this DWG has to be inserted into an ArcGIS-project. I also was thinking about just data-creation with Map3D and AutoCAD entities and then use MAPEXPORT to get a SHP exported!
Sorry for confusion!
- alfred -
Alfred NESWADBA
”Boost
