AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Create Legend in Tools of the Display Manager tab in Map 3D 2014
2 REPLIES 2
stephane.aubertin
4269 Views, 2 Replies
I'm in AutoCAD Map 3D 2014.
In Tutorial : Creating a Map Book With an Inset / Lesson 3: Create A Map Book / Exercise 1: Create a key map view and a legend /
4.Generate a legend that you can link to the Legend viewport.
    Switch the Task Pane to the Display Manager tab.
    Click Tools --> Create Legend....
I do not have to create a legend in the tool list.
To be able to create a legend , I must be in paper space and choose a viewport ( omething I 've seen on the web for earlier versions).
The same problem occurs in Tutorial: Building a Map / Lesson 6 : Creating a Legend
I use the tutorial provided in the Help Map 3D 2014 , not the WEB . I have a French tryout version of to MAP 3D 2014, but in an English version , I saw the same problem.
This is a sceen captur of the Display Manager tab Tools
Is this an error in the tutorial ?
Should I do something else, for the Create Legend to be in the tools menu ?
Is impossiblen create a legend in the model space ?
Thank you
Stephane A. Aubertin
Responsable - traitement de l'information (gestion des espaces)
Service de la planification et des projets immobiliers
HEC Montréal
www.hec.ca
2 REPLIES 2
In lesson 6 of exerice 1 of creating the legend look at step 8. You need to switch to the layout (paper space) to insert/create a legend. The tutorial is right just not written or explained as well as it could be.
Murph
Supporting the troops daily.
I think they forgot this explanation in the French translation. I just watch the Video, and they actually go in paper space.
thank you
HEC Montréal
www.hec.ca
”Boost
