HI!
I want to create layers based line lineweight using query Property Alterations. For example: if lineweight 0.00 then layers name is Null, 0.50-> Half, 1.00->One.
I created Range Table: IF=0.00 Return:Null, IF=0.50 Return:Half and IF=1.00 Return:One. Expression I used was Properties->LINEWEIGHT.
Result: when lineweight was 0.00 then this line moved to layer Null, but all other lines(lineweights 0.50 and 1.00) not moved to layers I wanted.
Also tried to use polyline instead lines and in range table also use "," instead "." but nothing, only 0.00 lines moved to desired layer.
I cant understand what I doing wrong.
Solved by olivier.eckmann. Go to Solution.
values of lineweight are from 0 to 211
for lineweight equal 0.50 you need to use 50
for 1.00 you need to use 100
Olivier
