AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Crashing during automatic save
1 REPLY 1
wrightsville1
270 Views, 1 Reply
My Autocad MAP 2011 keeps crashing everytime it does an automatic save.  Does anyone have a fix for this issue.
Thanks for the help!
1 REPLY 1
matTech
in reply to: wrightsville1
One of the first things I do after a fresh install is shut off automatic saves.  Type 'options' in the command line and it will be under the 'Open and Save' tab. Ctrl+'s' is your friend and use it often.  The crashes seem to occur while the program is thinking and saving at the same time.  If autocad is crunching, it's best to leave it alone.
”Boost
