With a little perseverance I managed to find the soluton to the problem via
the dot soft home page. It seems that the routine called adestrip.lsp will
remove the ade entity locks and the corrupted lock records that may be
related to this problem. When you apply the routine to an attached drawing
querying all layers in the draw mode in a drawing session as superuser and
then wblock the result, and when you attach the result back into a drawing
session and check the users in drawing maintenance the message "corrupted
lock record" is no longer there. For those who just want to get rid of the
unwanted regapps in a session, I think this is the way to do it.
Peter Giambattisto wrote in message
news:3BF35742.F925F65@sympatico.ca...
> Referring to the message of sept 6 2001. I cannot remove corrupted lock
> records after a save back error. I am logged on as superuser and the
> attached file is selected but the part of the dialog box with the remove
> locks button is not activated when I click user list and nothing is in
> the window box. I get an error code 14. Any Ideas?
> P.G.
