I have multiple weeks of shape file data and they are sent to me weekly. I'm trying to build a dwg using map instead of an ever growing CAD file with actual cad opjects in it (import shape files). After connecting to all of the data, I build a style for a set of polygon data based on property status. Does anyone know if I can copy that same style (theme) from one data connection in the display manager to another? (property status from this week to last weeks data) Or am I going about it all wrong? I have a pdf attached.
Solved by hence_the_name. Go to Solution.
Solved by Murph_Map. Go to Solution.
There's no easy way, although it's been on the wish list since FDO came about.
One way is to save the data connection layer to a .layer file. Then open that file in notepad or a simple text editor (it's an XML format file) and edit the file name in that file, then just load the new layer file. Of course the files have to be the same type with the same attributes for it to work. If you save the first layer file with a new name then each week edit that and save as with a new name.
Hi David,
the question comes a up every now and then. Here is a discussion with some further links:
Rob
