AutoCAD Map 3D General Discussion
*Expert Elite*
Alfred.NESWADBA
Message 11 of 16 (130 Views)
Re: copy/paste problem, probably easy fix, first time experience for me though
10-15-2013 02:50 PM in reply to: 1sccobb
can you upload those two drawings (source drawing and the drawing where you copy the objects to), if necessary reduce all drawings to a minimum, at least as many elements as needed to reproduce the issue.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
1sccobb
Message 12 of 16 (129 Views)
10-15-2013 02:54 PM in reply to: Alfred.NESWADBA
I can _insert and check the box to use geographic data and that puts it where its supposed to be, but one my attribute blocks is wildly out of scale. I can explode it and exactly 12 times to large.....
I can insert the attribute block into another drawing and it works fine
1sccobb
Message 13 of 16 (124 Views)
10-15-2013 03:05 PM in reply to: 1sccobb
I think I got it done right, should be just line work in model and a plan tab with the viewport, wasn't sure if you needed the viewport or not....
Thanks for taking a look....
 I'm headed home now, I'll check back tomorrow
*Expert Elite*
Alfred.NESWADBA
Message 14 of 16 (120 Views)
10-15-2013 03:44 PM in reply to: 1sccobb
Are you copying from modelspace to modelspace? If so I can do that without having anything wrong/scaled.
I used _COPYBASE (with basepoint 0,0,0) and _PASTECLIP into the other drawing.
Can you describe what objects are then scaled ... or better, can you upload the drawing with the already wrong pasted objects so we can compare to the drawings in the previous thread?
BTW: in both drawings the setting for "Scale objects from other drawings...." were set to yes, should be set to 0 in your case!
- alfred -
Alfred NESWADBA
1sccobb
Message 15 of 16 (108 Views)
10-16-2013 07:15 AM in reply to: Alfred.NESWADBA
Where do I go to change the drawing setting? I use _copybase from 0,0,0 and my drawings scale by 12 from the basepoint, I even used a northing/easting point on the magenta matchline on sheet 10, puts it in the right place, but scaled by 12
On sheet 10A, in model space, you can see the eliptical's are scaled. It's an inserted attribute from a dwg file
Here's the 10A sheet I wblocked out
1sccobb
Message 16 of 16 (94 Views)
10-16-2013 12:12 PM in reply to: 1sccobb
I got it working
Thanks for the help again
Now if I can figure out my Tiff file problem
Announcements
Need installation help?
