AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
copy part of pline intersectwith rectangle
5 REPLIES 5
imagination_s
317 Views, 5 Replies
Hello Everyone,
Could you please help me with something
I need to fiind a way to copy part of polyline  when the polyline intersect with a rectangle.Put that part of the polylines in separate layout.
But doing this thru autocad  2008 vba macro
A know there is something with getboundingbox and interechwith.
Thankyou so much for your help
The pictures above shows what i want
5 REPLIES 5
I'd simply run twice the _MAPTRIM command, sir.
Thankyou Sir Antonio Vinci,
unfortunately i need to copy part of pline programmable with vba ,
not to trim it.
It there a way to do that?
Thankyou for your help
Apreciated
Murph_Map
in reply to: imagination_s
You need to post here for that type of help.
Murph
Supporting the troops daily.
you already have found the correct forum (like >>>your thread<<<) and you already have got the answer 2 days before you started this thread here. Why are you creating that (and a lot more) crossposts, crossposts with same question in multiple forums, crossposts with similar questions (viewport instead of rectangle) again in other forums than VBA while you are asking for a VBA solution?
Please stop crossposting! Thank you!
....or let us know why you have got a solution in the VBA forum and you are asking that again in the Lisp forum, the Map 3D forum, Map 3D development forum, the Civil 3D customization forum, AutoCAD 2007-2009 forum, AutoCAD Architecture forum.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Sorry about posting
Thankyou for your help.I will use your hint and try to do this step by step.
Best regards
”Boost
