AutoCAD Map 3D General Discussion
*Kleiner, Jim
Message 1 of 4 (927 Views)
Copy Object Data
927 Views, 3 Replies
08-28-2002 12:11 AM
I have object data attached to some linework and I want to copy that data to
some new entities.
Is it possible to copy object data from one entity to another with out
having to fill in the table again
just wonderin'
*Crichton, Will
Message 2 of 4 (927 Views)
Re: Copy Object Data
08-28-2002 01:57 AM in reply to: *Kleiner, Jim
In the sample folder under your Autodesk Map install location you will find
a file called copy_od.lsp...
Load this puppy and then run the copy_od command...
Cheers,
Will
"Jim Kleiner" wrote in message
news:BABB6815CF9CDB1B4010243C98C8E997@in.WebX.maYIadrTaRb...
to
> some new entities.
> just wonderin'
> Thanks
BruceAdams
Message 3 of 4 (676 Views)
09-14-2012 01:03 PM in reply to: *Crichton, Will
this thread needs a bump...oh..laa  AUTODESK!  'copy_od' lsp works great....if you know that it exist's and where it is, and that you have to load it.  And then you can use it to save valuable cad time. :smileywink:
I just can't understand why Autodesk's map development is hiding these useful tools from users, and why aren't they exposing them in the ribbon yet?  This lsp routine has been around for -evah.  I'm on Map 2012 and still don't see it in the UI, whats up?
antoniovinci
Message 4 of 4 (654 Views)
09-16-2012 11:13 PM in reply to: BruceAdams
I concur definetely in it, sir.
Another noteworthy "pearl" is LISTPTS.LSP of Sample folder too, even if I found there a bug.
If pline coordinates has 7 digits or more, the result is not explicit, look at that:
