AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Copy Object Data
9 REPLIES 9
Message 1 of 10
2471 Views, 9 Replies
Copy Object Data
I have object data attached to some linework and I want to copy that data to
some new entities.
Is it possible to copy object data from one entity to another with out
having to fill in the table again
just wonderin'
9 REPLIES 9
Message 2 of 10
In the sample folder under your Autodesk Map install location you will find
a file called copy_od.lsp...
Load this puppy and then run the copy_od command...
Cheers,
Will
"Jim Kleiner" wrote in message
news:BABB6815CF9CDB1B4010243C98C8E997@in.WebX.maYIadrTaRb...
to
> some new entities.
> just wonderin'
> Thanks
Message 3 of 10
this thread needs a bump...oh..laa  AUTODESK!  'copy_od' lsp works great....if you know that it exist's and where it is, and that you have to load it.  And then you can use it to save valuable cad time. 😉
I just can't understand why Autodesk's map development is hiding these useful tools from users, and why aren't they exposing them in the ribbon yet?  This lsp routine has been around for -evah.  I'm on Map 2012 and still don't see it in the UI, whats up?
Message 4 of 10
antoniovinci
I concur definetely in it, sir.
Another noteworthy "pearl" is LISTPTS.LSP of Sample folder too, even if I found there a bug.
If pline coordinates has 7 digits or more, the result is not explicit, look at that:
Message 5 of 10
Rick.LabelleXRGFF
Hello, I have civil3d 2020 and cannot find copy_od.lsp
Does it exist in civil3d?
Message 6 of 10
here it is from AD2020
Message 7 of 10
Thanks so much. This is a huge time saver and a great way to reduce errors!
Why isn't this a preloaded function in Civil3d?
Come on Autodesk, let's get moving!
Message 8 of 10
Barzdil
in reply to: Rick.LabelleXRGFF
Hello, as for OD functionality, Alexander seemed to have mentioned in this forum that Autocad Map hasn’t changed completely in decades. I think there are bitter agreements between autocad and additional application developers that specifically offer such additional functionality as OD 🙂
Message 9 of 10
braudpat
Hello @Anonymous  @Barzdil  @Rick.LabelleXRGFF  @parkr4st  @antoniovinci
1) Please look at this very important Topic :
https://forums.autodesk.com/t5/autocad-map-3d-forum/additions-for-object-data/td-p/7548282
Where you will find many Routines about ODs (Object Data) of ACAD MAP & ACAD CIVIL ...
2) Without these routines using ODs is a nightmare !
3) I have about a dozen of Lisp/VLisp routines preloaded on my ACAD MAP about ODs !
The Health, Bye, Patrice (The Old French EE Froggy)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 10 of 10
... and - Applications for Object Data - Autodesk Community - AutoCAD Map 3D
or the Additionally section on my dedicated odclass-odedit website, where most of the existing lsp and arx for OD are collected.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
”Boost
