AutoCAD Map 3D General Discussion
0 Kudos
Post 1 of 11
Coordinate transformation
463 Views, 10 Replies
05-03-2012 11:13 AM
How could I transform the following :
PROJCS["albers_dep",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Albers"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-78.0],PARAMETER["Standard_Parallel_1",40.0],PARAMETER["Standard_Parallel_2",42.0],PARAMETER["Latitude_Of_Origin",39.0],UNIT["Meter",1.0]]   Into UTM83, zone 18, Feet?
I will greatly appreciate any help.   Thanks!!!!
194 Kudos
Post 2 of 11
Re: Coordinate transformation
05-03-2012 11:22 AM in reply to: lesnavar16
You need to transform ALL your shape, not only that .PRJ file.
There are some ways to convert it, the easiest one is:
1] set UTM83 Zone 18 Feet as main CRS with _ADESETCRDSYS
2] run _MAPIMPORT and load the shape, choosing the Albers' one as CRS going in.
0 Kudos
Post 3 of 11
05-03-2012 11:53 AM in reply to: antoniovinci
Thanks!  I will try that.
0 Kudos
Post 4 of 11
05-03-2012 01:50 PM in reply to: antoniovinci
Unfortunately, it did not work.  Any other suggestion?
Please, I woud really, really be greatful for any help given.
194 Kudos
Post 5 of 11
05-04-2012 12:30 AM in reply to: lesnavar16
It doesn't work, 'cause you surely have not chosen the Albers' CRS as going in: please attach your MAPIMPORT screenshot, I'll prove it to you.
Valued Mentor
35 Kudos
Post 6 of 11
05-04-2012 03:00 AM in reply to: antoniovinci
open a new dwg and set the coord system to UTM83-18F.  You may desire to add some dwg layers that you use regulary to the dwg and save that dwg as a template file.  That template can be opened anytime you want to do a map with that coord system.
Use data connect and connect to your .shp file.  You will see two heading schema and coordinate system.  The cs will either have your albers listed or <unknown>  if it is <unknown>, click edit coord systems and set it to the alber cs.  and then click add to map.  The .shp will be tranformed onto the UTM83-18f.
In Display manager, right click the layer name and do two things, first save layer to a .layer file so anytime you need that layer back in a map you can drag and drop the .lyr file from windows explorer; and second export layer data to SDF which will save the layer in the SDF format.  That can alo\so be dragged and dropped into a map or data connected if your need to query the layer data.
You also have the option on the task pane, map explorer tab, tools>bulk copy and create a new shape in the UTM83-18F cs.
Dave
0 Kudos
Post 7 of 11
05-04-2012 07:38 AM in reply to: parkr4st
Thanks a million, Dave.
0 Kudos
Post 8 of 11
05-06-2012 07:29 AM in reply to: lesnavar16
Still struggling.  Of the Albers projection, I only have available: 48 States; NAD27 Albers Equal Area, 1:2,000,000 DLG Files, Meter.  I need:  48 States; NAD83 Albers Equal Area, 1:2,000,000 DLG Files, Meter.  How do I get or find the latter? Please, HELP!
Thanks a million,
Les
Valued Mentor
35 Kudos
Post 9 of 11
05-06-2012 11:12 AM in reply to: lesnavar16
The closest I see is US48-epng.
try this.  I think it gives you what you want but don't garantee it
mapscslibrary
find US48-epng
hi lite and then click the duplicate button
US48-epng_1 is created
hi lite it and click edit
Rename it if you want
change feet to Meters
click view and see if has the parameters you want.
close and then mapcsassign and use it
If it is what youy need you're good to go.  Other wise try Corpscon software from the Army Corps of Engineers, that may help.  Tommorrow others will be back at work and may provide another solution.
Dave
0 Kudos
Post 10 of 11
05-06-2012 12:57 PM in reply to: parkr4st
I have tried it already. It did not work.  Thanks, Dave, for trying to help.  I really appreciate your effort.
